Car jerking need help!
#31 OFFLINE
Posted 13 September 2014 - 01:27 PM
#32 OFFLINE
Posted 13 September 2014 - 01:31 PM
I think the screw holes in the TPS are slotted, they should allow it to be turned enough to adjust the settings.
Loosening the screws and turning the sensor itself is the way to do it
EV Rolling, 5 doe MoFo. BOOM!
"Built like a steakhouse, but handles like a bistro"
#33 OFFLINE
Posted 13 September 2014 - 01:38 PM
#34 OFFLINE
Posted 13 September 2014 - 01:52 PM
Sure i read of someone using the negative battery terminal, does that sound right?
Not sure myself really, dont want to let you down after you have got this far, i will try to find where i read that and link it.
Hope this will help to solve your problems, at least if you test it and its okay then you know the TPS is not the issue.
#35 OFFLINE
Posted 13 September 2014 - 01:58 PM
More info here: http://forums.clubrs...ad.php?t=585478
On a DC5 but same principle, posts 9 and 10 say the radiator support, so a solid piece of framework should be okay for a ground.
#36 OFFLINE
Posted 13 September 2014 - 02:08 PM
#37 OFFLINE
Posted 13 September 2014 - 02:15 PM
#38 OFFLINE
Posted 13 September 2014 - 02:20 PM
The circuit has to be connected i believe, seen people (carefully!) push a paper clip into the back of the connector where the wire joins the pins to attach a voltmeter, saves shaving any insulation.
#39 OFFLINE
Posted 13 September 2014 - 07:32 PM
ok I will put some small pin in to it. But today after I was checking tps, came on ecu or engine light on and now I am so angry I hope I did anythink wrong to it....
#40 OFFLINE
Posted 13 September 2014 - 09:12 PM
Oh crap! Worried i may be causing more problems than fixing anything here.
Could be a response from the ECU from unplugging the TPS?
#41 OFFLINE
Posted 14 September 2014 - 07:41 AM
#42 OFFLINE
Posted 14 September 2014 - 08:52 AM
Hope it works out, keeping fingers crossed for you buddy.
#43 OFFLINE
Posted 15 September 2014 - 09:46 AM
#44 OFFLINE
Posted 15 September 2014 - 03:21 PM
Damn! Was hoping that would fix your problems, sorry to hear it was not the case
Impressed that you took the job on and made it happen, a credit to you, if you love your car (as i am sure you do) then it will be worth getting it looked at by Honda.
Maybe you could get them to find the problem and let you know before doing any work to the car?
#45 OFFLINE
Posted 15 September 2014 - 04:12 PM
