slight whistle noise appears , could be gearbox???
#16 OFFLINE
Posted 13 April 2010 - 08:38 PM
#17 OFFLINE
Posted 19 April 2010 - 10:36 AM
so the car parked up till i can afford to get it fixed
#18 OFFLINE
Posted 19 April 2010 - 10:47 AM
#19 OFFLINE
Posted 19 April 2010 - 01:03 PM
im hoping its only gearbox bearings, which is fixable and far more less costly than a replacement recon gearbox
#20 OFFLINE
Posted 19 April 2010 - 04:25 PM
the noise is loud in 1st 2nd 3rd 4th between 1500 and 4000 rpm
Do you have ICE installations in the car so noise come's from speakers??
#21 OFFLINE
Posted 02 May 2010 - 04:09 PM
Are you seriously trying to take the piss ???
#22 OFFLINE
Posted 02 May 2010 - 08:20 PM
You have to ask that question to your self
#23 OFFLINE
Posted 02 May 2010 - 10:36 PM
#24 OFFLINE
Posted 03 May 2010 - 10:14 AM
Just a suggestion
But it does sound like the gearbox tbh, my car has the noise too just not as loud. I can only hear it when im stationary. Once I get moving i can't hear it (probably because of my buddy club...)
It shouldnt be too expensive to get your 'box fixed. A few hundred squid and a day or two at Honda depending on how busy they are.
Whistling noises could also be coming from the clutch thrust bearing or the alternator (as stated earlier in this thread). Personally I would just take the car to Honda before anything breaks. Sounds like the noise is getting worse.
One thing to remember about bearings. If they fail, they generally seize completely. My friends wheel bearing in his Mini failed and locked the front left wheel which caused him to veer off onto the pavement uncontrollably (thank f**k no-one was there!). And i dont think you'd want a gearbox bearing to do that
#25 OFFLINE
Posted 03 May 2010 - 01:53 PM
I was told the bearings won't break completely until the noise in the car is unbearable in all gears. So you should be fine for the near future.
#26 OFFLINE
Posted 03 May 2010 - 02:06 PM
