slight whistle noise appears , could be gearbox???
Posted 08 April 2010 - 09:43 PM
Any ideas ???
Posted 09 April 2010 - 05:07 AM
Posted 09 April 2010 - 07:22 AM
Posted 09 April 2010 - 09:55 AM
ive just noticed when i engage the the clutch in neutral its making the same noise but louder and the same noise in all gears driving between 1500 rpm 2500 rpm .
Whaqt can i do , is this an easy fix??????
Posted 09 April 2010 - 10:01 AM
Posted 09 April 2010 - 10:09 AM
Posted 09 April 2010 - 07:27 PM
Posted 09 April 2010 - 10:27 PM
Posted 12 April 2010 - 10:09 PM
Mines been like it forever. had it checked and apparantly its fine. dont know if yours is the same noise though, just ask a garage (that you trust and arnt cowboys)
Same mate, i only get it when the car is rely cold but been told its nothin to worry about, i hope lol.
Posted 12 April 2010 - 10:14 PM
Cost £250 for a specialist in Rutherglen to replace all the gearbox bearings ("TopGear"). Dropped the car off one night, picked it up the next evening.
You could give them a try:
http://www.google.co... ... kUjzWGszPw
Posted 13 April 2010 - 09:57 AM
http://www.google.co...url?sa=t ... kUjzWGszPw[/quot
thanks for reply ross , the think is i have got a cashflow problem at the moment due to not workin , but what would happen if a continued driving , would it total the gearbox??
Posted 13 April 2010 - 10:06 AM
Posted 13 April 2010 - 11:58 AM
Posted 13 April 2010 - 03:55 PM
think you find its yr first motion shaft bearing! inside the gear box, as the revs go up the bearing will spin faster making the noise louder, will be an expensive job if u dont know the right people, and dont leave it like i did it only gets worse.
Smithy has the right idea here,
way to check this is - start up in 1st, get rolling, then put it in neutral and lift your clutch pedal, if u get a whirring, winding/whislting noise, then this could or most likely is the bearings as mentioned above. or could be the clutch release bearing. this is a big job as the engine/gearbox requires lifting. could cost quite a few £££s too, most of that will be labour expense.
edit: as mentioned above, this is a common-ish thing in Honda's not only Civics - only unless its screaming at you then i would be worried.
in the meantime, dont drive it like its stolen
Posted 13 April 2010 - 04:47 PM
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
