While its on or off??? The car? Should the footbrake be pumped when the car is off ?Hi mate.
You have to reset the callipers.
To do this you need to loosen the adjuster bolt at the handbrake lever right down till its on the last threads, then pump the footbrake quite hard 20 - 30 times, then screw the adjuster nut back up till it holds the car after about 4 - 6 clicks. http://www.epcivic.c...con_twisted.gif
HELP!!EP2 handbrake problem
davveep2
, Mar 23 2010 08:19 PM
15 replies to this topic
#16 OFFLINE
Posted 06 July 2013 - 08:31 AM
