HELP!!EP2 handbrake problem
Posted 23 March 2010 - 08:19 PM
Its so bad i can actually drive the car with it on
i tryed tightning it but is hardly holds the car i dont think the calipers are seized and honda dont think its the cables... any ideas?
it failed mot as partly because of this last week
all help apprecated thanks
Posted 23 March 2010 - 08:21 PM
where did you adjust it from.
Posted 23 March 2010 - 10:57 PM
Posted 23 March 2010 - 11:02 PM
Posted 24 March 2010 - 12:31 PM
New pads, greasing, cleaning and right kind of adjust to the pistons, handbrake cables check and adjust.
My handbrake works good but i use it every week. little tip: Use while driving example when you come traffic lights.
Posted 24 March 2010 - 06:28 PM
Posted 24 March 2010 - 06:41 PM
duno if this helps its the how to for adjusting the handbrake.
Luke
Posted 24 March 2010 - 07:15 PM
http://type-r-owners...n-EP3-Handbrake
Luke
i tryed this but still same thanks
Posted 24 March 2010 - 10:06 PM
Posted 25 March 2010 - 09:31 PM
Posted 25 March 2010 - 09:39 PM
You have to reset the callipers.
To do this you need to loosen the adjuster bolt at the handbrake lever right down till its on the last threads, then pump the footbrake quite hard 20 - 30 times, then screw the adjuster nut back up till it holds the car after about 4 - 6 clicks.
Posted 26 March 2010 - 06:05 PM
Hi mate.
To do this you need to loosen the adjuster bolt at the handbrake lever right down till its on the last threads, then pump the footbrake quite hard 20 - 30 times, then screw the adjuster nut back up till it holds the car after about 4 - 6 clicks. http://epcivic.com/f...tyle_emoticons/default/icon_thumbup.gif
prefect http://epcivic.com/f...tyle_emoticons/default/icon_thumbup.gif all sorted now thanks
Posted 26 March 2010 - 09:50 PM
Posted 26 March 2010 - 10:26 PM
Posted 05 July 2013 - 08:02 PM
I need to try this my Handbrake is pants
