The metal peg touches your brake disc and you hear the squeal, it sometimes squeals even if your not using your brake.
Your probably better to get them checked and/or replaced sooner rather that later, the reason is the longer you leave then squeaking, the more chance there is of the indicator peg starting to grind into your shiny brake discs! we of course you dont want!
Home this helps
