redline
Posted 16 December 2009 - 08:31 PM
what is the redline limit on the k20a ep3 engine standard?
thanks
Posted 16 December 2009 - 09:47 PM
hello
thanks
UK spec K20A2 will be 8,250rpm.
Aaron
Posted 17 December 2009 - 06:49 AM
Posted 28 December 2009 - 09:19 PM
Posted 28 December 2009 - 10:39 PM
Are you taking the piss??redline the car is not gaining anymore power....than hitting the vtec point then change gear. Change gear earlier will get the best performance. Unless your car is highly tuned!!!
Posted 30 December 2009 - 01:06 PM
If you look at EP3 dyno result you can see power drop after 8000 rpm's so you don't have to rev to the redline.
but change gear before vtec point
Posted 30 December 2009 - 10:26 PM
I know it drops off after 8k rpm, but to change before vtec would be pointless. You wont be getting the full power of the engine. You might aswell buy an Astra.Are you taking the piss??redline the car is not gaining anymore power....than hitting the vtec point then change gear. Change gear earlier will get the best performance. Unless your car is highly tuned!!!
Posted 30 December 2009 - 10:38 PM
Saying that, I wouldnt mind the VXR in arden blue!
Posted 31 December 2009 - 01:45 PM
FAIL
Posted 31 January 2010 - 07:20 PM
Posted 31 January 2010 - 10:33 PM
my thoughts as well , hit the vtech then change gear hahaha hit the vtech and keep going and feel the rushAre you taking the piss??redline the car is not gaining anymore power....than hitting the vtec point then change gear. Change gear earlier will get the best performance. Unless your car is highly tuned!!!
Posted 01 February 2010 - 12:05 AM
I don't know how you interpreted Epmon's text, but I'm pretty sure that's not what he meant. Let me type in how I understood his writing:
Redlining the car (close to limiter) will gain as little power as hitting the vtec point and then immediately changing gear. Gear change earlier (just on the redline) will get the best performance. However, if your car is highly tuned then the car will produce it's max hp on and over the limiter (see Remould's car) thus you should drive like a wacko
Posted 01 February 2010 - 01:11 PM
Whats vtech I think you mean VTEC.my thoughts as well , hit the vtech then change gear hahaha hit the vtech and keep going and feel the rushAre you taking the piss??redline the car is not gaining anymore power....than hitting the vtec point then change gear. Change gear earlier will get the best performance. Unless your car is highly tuned!!!
Posted 05 February 2010 - 02:15 AM
Go for green!hey gus where did you get them orange wheels mate there awesome thinking either orange or green, havent made my mind up yet
I loves my VTECH!!
Posted 05 February 2010 - 10:15 AM
