k20 engine design
6 replies to this topic
#1 OFFLINE   AD09
AD09
    Newbie
  • 22 posts
Posted 20 November 2009 - 12:02 PM
Random question
Does anyone know why the k20 looks like its the opposite way round in the engine bay to other honda engines, with the inlet at the front of the engine bay and exhaust mani running out the back. It looks like where the airbox is at the back of the bay isn't a good place to get airflow. If the enigne was turned 180 degrees it would be layed out like or honda engines with the induction system running down the left side towards the front, inlet main at the back and exhaust mani at the front. Anyone know why they choose to do it this way lol :D
#2 OFFLINE   coco-loco17
coco-loco17
    Top Contributor
  • PipPipPipPipPipPipPip
  • 5345 posts
  • LocationKdy
Posted 20 November 2009 - 01:32 PM
gives the exhaust better flow :D
#3 OFFLINE   Gus-ep3
Gus-ep3
    Vtec Junkie
  • 3918 posts
  • LocationBiggar
Posted 20 November 2009 - 05:40 PM
I think its the sencible way to go, as the hot exhaust mani is at the rear and the cold intake at the front. :D
#4 OFFLINE   brizbraz
brizbraz
  • 1408 posts
  • LocationDundee
Posted 21 November 2009 - 09:28 AM
Straighter exhaust setup helping flow and also no exhaust running under the sump meaning that you're not heating the oil up as much (Spoon actually make a specific heat wrap kit to put over the sump in engines where the exhaust runs under the sump) and also the engine can be set lower in the chassis helping the centre of gravity.
Also, in racing, most cars have ITBs and they're better off sticking out towards the grille for maximum airflow.
#5 OFFLINE   Shane
Shane
  • 275 posts
Posted 05 January 2010 - 07:36 AM
Although in s2000's the k20's sit sidewards so manifold is on the left and intake runs down the right
#6 OFFLINE   James
James
  • 1491 posts
  • LocationSlovakia
Posted 05 January 2010 - 03:26 PM
apart from that the s2000 does have a F series engines, not K ones...
#7 OFFLINE   brizbraz
brizbraz
  • 1408 posts
  • LocationDundee
Posted 05 January 2010 - 11:10 PM
The S2000s have F-series engines (either 2.0l or 2.2l) and the engine is mounted longitudinally as the car is rear-wheel drive.
