EP3 - Pre-Facelift & Facelift
Posted 16 May 2009 - 01:00 PM
Posted 16 May 2009 - 01:06 PM
buying a prefacelift and adding the bumper and headlights is a good plan and gives you all the looks and saves money, good plan
Posted 16 May 2009 - 01:47 PM
prefacelift ftw! better front bumper, better tail-lights, and there cheaper
Posted 16 May 2009 - 01:54 PM
Projector headlights
Different rear light clusters
Different grille
Different front bumper
Wheels are slightly darker and no longer have "Enkei" stamped on the back (I've read arguments about this on other forums, but I think the wheels are identical apart from these two very small differences, i.e. neither are lighter or "better" than the other)
Red inserts on the front seats
Red inserts on the door cards
Lighter flywheel (original changed for that found in the JDM CTR)
Some slight changes to the steering
Some slight changes to the suspension (though I'm thinking probably just a tiny geometry change tbh)
Some more soundproofing making the facelift slightly heavier, but the lightened flywheel more than compensates for this as far as acceleration is concerned.
Engine, gearbox and brakes are exactly the same
Posted 16 May 2009 - 02:07 PM
Posted 16 May 2009 - 02:50 PM
Posted 16 May 2009 - 03:00 PM
and hold it on the way back up that sounds even dirtier
Posted 16 May 2009 - 04:16 PM
Facelift FTMFW
Posted 16 May 2009 - 04:23 PM
one click down just looks suave when you pull up at the petrol station though
keep your lexarse lights, pre pre prefacelift ftw!
Posted 16 May 2009 - 04:57 PM
Posted 16 May 2009 - 06:11 PM
Posted 04 August 2009 - 08:16 PM
Posted 04 August 2009 - 09:37 PM
Posted 04 August 2009 - 10:13 PM
The facelift has a lighter flywheel, so rev's easier.
