Civic Audio Information.... FAQ.
Posted 14 December 2008 - 01:37 PM
76220-S5T-A01ZA GARNISH, R. DOOR MIRROR (TWEETER) $8.22
76270-S5T-A01ZA GARNISH, L. DOOR MIRROR (TWEETER) $8.22
Autoleads Honda-ISO Adaptor Part Number
PC2-68-4: Listed as:Honda Accord 09/98>, All UK 99> ISO lead
This is required for ALL installations unless there is already an aftermarket unit fitted.
Autoleads Honda Civic EP2-EP3 Facia Adaptor Part Number
FP-15-03-s : Silver Version
FP-15-03 : Black Version
Autoleads Din-ISO Antenna Adaptor Part Number
PC5-28: This is needed for Alpine head unit installations. Kenwood, Sony, JVC, Pioneer etc generally dont need this but it may change on the newer models so its best to check.
Autoleads Front Speaker Adaptor Plate Part Numbers
SAK-2902: These are listed as Vauxhall Vectra mounts but they work well in Civics. Using these plates you can fit 16/17 cm speakers. If you use the plates intended for the civic then you will be restricted to 13cm speakers
Speaker Sizes:
16.5cm 17cm and 6inch speakers will fit in both front and rear locations.
Rear locations will accept nearly all speaker sizes without serious modifications.
Front doors have a hole behind the original speakers which might need to be enlarged to accommodate the larger magnets on some aftermarket speakers. Max depth is around 80mm with an 18mm spacer.
Speaker Wire Colours and Polarity.
Front Left
(+) Green/Black
(-) Light Green
Front Right
(+) Green/Yellow
(-) Grey/Red
Rear Left
(+) Blue/White
(-) Blue/Black
Rear Right
(+) Pink
(-) Blue Yellow
(Thanx to StuDaPoo)
If i can find any other relevant info i will add it in..
Gav.
Posted 15 April 2009 - 07:33 PM
Picking mine up later
Cheers
Shane
Posted 09 June 2009 - 02:30 PM
V H76220S5TA01ZA N/STK GARN,R DOOR*NH1L*
V H76270S5TA01ZA N/STK GARN,L DOOR*NH1L*
£15.20 INC VAT FOR BOTH OF THEM NEXT DAY DELIVERY
i was watching some the went for £25 on
Posted 12 March 2010 - 05:50 PM
Posted 06 April 2010 - 10:03 AM
Posted 13 April 2010 - 05:55 PM
this may be a stupid question but see the front door brackets how do they attatch to the door? the oem ones arnt just screws obviously and if I just screw the bracket in it will move no?
tell me if thats daft question haha
cheers
#7
Posted 13 April 2010 - 06:06 PM
What brackets are you referring to?this may be a stupid question but see the front door brackets how do they attatch to the door? the oem ones arnt just screws obviously and if I just screw the bracket in it will move no?
#8
Posted 13 April 2010 - 08:05 PM
#9
Posted 14 April 2010 - 07:35 AM
#10
Posted 14 April 2010 - 12:11 PM
#11
Posted 14 April 2010 - 01:01 PM
If you can find speakers that use the 3 holes then yes. Pro installs use adapter plates aswell. However, they are almost without exception 4 hole installs. That means you still have to drill new holes if you want better speakers. And let's face it, even those OEM-replacements suck serious ass compared to any real component/coaxial setup.awwww thats not the best. me and power tools are generaly a no no. maybe i could make an adaptor out of mdf for example. attatch it using bolts n washers. that might be crazy enough to work
#12
Posted 14 April 2010 - 05:48 PM
#13
Posted 17 April 2010 - 03:15 PM
what i did was basicaly take a .75 inch sheet of plywood and make a shape like 3/4 of a circle making sure the speaker fits within it.
then with the open end facing the bottom of the door, mark on the wood where the OEM holes are, Drilled holes for 3 bolts where i marked the wood (i used a special bit so that i can recess the bolt heads into the wood so the speaker sits flush), thats basicaly the adaptor.
then once the bolts are in place in the adaptor attach it to the door using nuts and penny washers. once attatched i just connected and screwed the speaker to the adaptor.
i realise its a bit of a carry on what with the cutting etc but its effective if you dont want to drill holes in the door lol
#14
Posted 29 July 2010 - 10:01 AM
