Changing rear speakers
11 replies to this topic
#1 OFFLINE   Cody
Cody
  • 1476 posts
  • LocationSutton Coldfield
Posted 20 March 2010 - 10:44 PM
Can anybody suggest any speakers that are the same size as the standard rear ones please. My new stereo needs some new speakers. I don't wanna have to do modifications to anything, I just want them to slot in the same space and preferably have multiple screw point so I can screw into the same holes.
Cheers
#2 OFFLINE   Neil
Neil
    Scottish Mod
  • Moderator
  • 3944 posts
  • LocationDundee/Alloa
Posted 07 April 2010 - 10:37 AM
hey man 13.5 cm speakers fit just nicley into the space. i have Fli speakers in mine although im not using them. Want to fabricate a bracket for 6x9s lol.
hope this helps
Neil
#3 OFFLINE   Cody
Cody
  • 1476 posts
Posted 08 April 2010 - 12:15 PM
Alright dude, Sorted ages ago, Bought some 6" FLI integrators for £25, better than the standard ones and more bass from them, just the left one makes annoying vibrating noises when bass comes in so I reckon something needs securing or buffering.
Cheers anywho mate
#4 OFFLINE   pooley
pooley
    Junior Member
  • 81 posts
Posted 19 June 2010 - 04:19 PM
+1..... i just did this, much better!! :(
#5 OFFLINE   BassKicksDan
BassKicksDan
    Deserter :P
  • PipPipPipPipPipPipPipPip
  • 6614 posts
  • LocationOxfordshire
Posted 19 June 2010 - 04:38 PM
Do these fit in the standard brackets?
#6 OFFLINE   RobbM
RobbM
  • 195 posts
Posted 20 June 2010 - 12:15 AM
Pack of M6 nuts and bolts, 2 MDF Speaker rings and your choice of 6.5" speaker.
Mount the rings to the metal and plastic, drill out the holes if needs be. and use a drill bit bigger than the bolt head to counter sink it.
Pre-drill some small 3MM holes, then screw the speaker into the MDF rings using self tappers.
Sound deaden the metal behind it too if you have some. It will make the word of difference, especially if your running off the headunit. The rear quarters ring like feck! Give them a tap with your knuckle on the outside. That ringing is wasted bass :(
#7 OFFLINE   Aman
Aman
  • 301 posts
Posted 20 June 2010 - 03:30 PM
anyone have any idea of the max mounting depth of the rears?
with spacers and all... cheers
#8 OFFLINE   RobbM
RobbM
  • 195 posts
Posted 20 June 2010 - 07:59 PM
Shouldnt have a problem as there isnt a window to foul or anything. Not many normal speakers will be that deep. If it is, just double up on 18MM rings.
#9 OFFLINE   Aman
Aman
  • 301 posts
Posted 20 June 2010 - 11:22 PM
so 185mm shouldnt be too deep?
#10 OFFLINE   RobbM
RobbM
  • 195 posts
Posted 21 June 2010 - 10:52 PM
What exactly are you trying to install? 185MM seems a bit bif for conventional 6.5" speakers. You may well need 2 speaker rings, but it'll just make it more solid ime.
#11 OFFLINE   Aman
Aman
  • 301 posts
Posted 21 June 2010 - 10:58 PM
Sorry I got muddled up the depth is only 95 mm so I take it thatll be fine with a few rings or so.
Cheers guys.
#12 OFFLINE   RobbM
RobbM
  • 195 posts
Posted 21 June 2010 - 11:03 PM
should be fine without, but id use one for strength.
