installing headunit
12 replies to this topic
#1 OFFLINE   CivicS
CivicS
  • 163 posts
  • LocationMalta
Posted 03 December 2009 - 05:41 PM
Can anyone tell me how i can undo the two 8mm bolts inside the console?? i cant reach them with a spanner and they are too tight to undo using a screwdriver http://epcivic.com/f...tyle_emoticons/default/sad.gif
#2 OFFLINE   Andy
Andy
  • 256 posts
  • LocationNorth Wales
Posted 04 December 2009 - 01:10 AM
Left hand side one can be accessed by taking the glovebox out and reaching from the inside (squeeze the sides of the 'box and it should fall down loosely) and the right one is a bit more difficult, there's a plastic panel just below the left of the steering wheel that you can remove and go in the same way. Keep at it and you'll get there in the end!
Just make sure you don't drop the bolts http://epcivic.com/f...tyle_emoticons/default/wink.gif and be aware your hands will probably take a battering!!
#3 OFFLINE   yung
yung
    EPC Supporter
  • PipPipPipPip
  • 908 posts
  • Location.
Posted 11 December 2009 - 07:21 PM
Don't use a screwdriver, best thing is a 8mm offsetted spanner!
Takes time but well worth it :thumbup:
#4 OFFLINE   BassKicksDan
BassKicksDan
    Deserter :P
  • PipPipPipPipPipPipPipPip
  • 6614 posts
  • LocationOxfordshire
Posted 21 April 2010 - 02:45 PM
Bump,
I was wondering if anyone had photos of them installing the head unit? When payday comes around im going to start work on installing my new head unit and sub but have no idea where to start!
#5 OFFLINE   jeunaske
jeunaske
    Net-front presence
  • 1146 posts
  • LocationFinland
Posted 21 April 2010 - 03:02 PM
Bump,
How's this?
http://www.civictype..._Head_Unit.html
#6 OFFLINE   martinj46
martinj46
  • 1302 posts
  • LocationAberdeen
Posted 21 April 2010 - 03:04 PM
http://www.fitaudio....ntry&EntryID=19
That's quite a good guide there.
I'll be removing mine to put the standard one back in at the weekend, so if I remember I'll take some pictures and write up a how-to
#7 OFFLINE   BassKicksDan
BassKicksDan
    Deserter :P
  • 6614 posts
Posted 22 April 2010 - 06:04 PM
Me and some friends are going to attempt this next week. Just need to wait for J4RED to get back to me so i can buy his harness adaptor. Thats the only thing I need :thumbup:
I will post some pictures :thumbup: seems simple enough...*touch wood*
#8 OFFLINE   jeunaske
jeunaske
    Net-front presence
  • 1146 posts
  • LocationFinland
Posted 22 April 2010 - 06:42 PM
Me and some friends are going to attempt this next week. Just need to wait for J4RED to get back to me so i can buy his harness adaptor. Thats the only thing I need :P
I will post some pictures :P seems simple enough...*touch wood*
It is simple. When you do it once, you can do it again... again... again... juggling the headunit in and out probably 15 times like me for different reasons :thumbup:
The only thing you might struggle with are the two bolts that hold the top console piece. In my car they'd been tightened over-happily from the factory. Thanks to that, cut my hands ~4 times when getting them loose. When you put the console back together don't overtighten the bolts! Easier for yourself the next time you crack it open :thumbup:
#9 OFFLINE   Spectre
Spectre
  • 1715 posts
  • LocationE
Posted 22 April 2010 - 08:00 PM
A little stubby philips is all ya need, you go in as discribed above, through the glove box and through the fuse panel cover on the other side. you dont need to remove them, just loosen them.
#10 OFFLINE   BassKicksDan
BassKicksDan
    Deserter :P
  • 6614 posts
Posted 22 April 2010 - 08:22 PM
Awesome thanks :thumbup:
Yeah i was thinking "how hard can it be!" Just remove a few things, plug it in, and hey presto!
I just didnt know what to expect :thumbup:
The dashboard adaptor thing we need for aftermarket head units, we only need one of them right?
#11 OFFLINE   Spectre
Spectre
  • 1715 posts
  • LocationE
Posted 22 April 2010 - 11:08 PM
Facia adapter and an ISO lead, thats all. :thumbup:
#12 OFFLINE   martinj46
martinj46
  • 1302 posts
  • LocationAberdeen
Posted 23 April 2010 - 08:11 AM
The hardest part is getting the dashboard out for the first time. It took a lot of patience when I did it.
Depending on what headunit you've got you may need an aerial adapter aswel. Alpine's do. Not sure about any others
#13 OFFLINE   BassKicksDan
BassKicksDan
    Deserter :P
  • 6614 posts
Posted 23 April 2010 - 11:24 AM
yeah ive got an alpine head unit. I think it came with an aerial adaptor. Its a tiny black lead with coax-lookalike connector on it.
