Fitting Full ICE
11 replies to this topic
#1 OFFLINE   Jonny_H
Jonny_H
  • 1406 posts
Posted 12 March 2008 - 08:52 AM
how hard is it to do the wiring kit?
i've done quite a few saxos/corsas so i know what im doing but not sure if theres going to be any probs doing the civic?
also some1s told me that facelift civics have some sort of special wiring which can cause probs, anyone heard of this
#2 OFFLINE   Ash
Ash
    I am God! haha
  • Administrator
  • 7298 posts
  • LocationDerbyshire
Posted 12 March 2008 - 01:38 PM
i paid someone to fit mine :lol:
but it didnt take him long!!
it was that easy i rewired it myself when i moved the cables from side of car to down the middle.
Rockin' a Supercharged 06 NHB Premier R - view
TDi Tuned - 294.9 bhp 191.3 lbft @ 6 psi
JRSC | KPro | Gruppe M | Piper | CPL | HKS | Recaro | Rota | ABP | HID | SFS | JDM
05 NHB EP2 - bye! > 06 NHB EP3 - hello!!
Daily : Nissan Juke Nismo RS
PSN : ashpb | XBOX : a5hpb
#3 OFFLINE   NHBANDYD
NHBANDYD
  • 473 posts
Posted 12 March 2008 - 03:10 PM
I did my soundsystem and the only tricky part is getting the headunit out as its quite awkward, its hard not to scratch the gear stick facia thing too!
But the rest is fine i earthed my boot amplifier onto one of the bolts just behind the rear left seat under the panel, Wire routing is easy in the civic too, i used the grommet behind the glove box to get inside the car from the engine bay.
:lol:
Edit: mines a prefacelift but i havent heard about the issues you heard
#4 OFFLINE   Crussells
Crussells
    Elite Member
  • PipPipPip
  • 524 posts
Posted 12 March 2008 - 04:45 PM
its pretty easy to do mate, if your not sure get a wiring diagram (amp wiring kits tend to have them), basically connect this cable here and that cable there etc...
its one of those that you shouldnt cut corners on though, make sure you use connectors, insulate any bare wires and make sure you dont run the power cable and phono leads side by side as it will cause interferance through your speakers...
if your really unsure get a proffesional to do it, i used to fit alot of audio gear in ma last job and have saw alot of bad jobs, and some really dangerous stuff that i dont know how it hadnt caought fire that there "mate" had done for them. lol realise this sounds pretty doom n gloom just cant stress enough how doing something like this correctly, saftey first and all that :lol:
#5 OFFLINE   Ash
Ash
    I am God! haha
  • Administrator
  • 7298 posts
Posted 12 March 2008 - 05:58 PM
Mines done same as that, its earthed to the rear seat bolt, think it need tightening up because sometimes the amp dont turn on! :lol:
#6 OFFLINE   NHBANDYD
NHBANDYD
  • 473 posts
Posted 14 March 2008 - 11:24 AM
Mines done same as that, its earthed to the rear seat bolt, think it need tightening up because sometimes the amp dont turn on! http://epcivic.com/f...tyle_emoticons/default/icon_mad.gif
Yea and try cleaning/sanding the metal where it touches incase theres anything thats stopping it conducting well.
#7 OFFLINE   Jonny_H
Jonny_H
  • 1406 posts
Posted 19 March 2008 - 11:05 AM
Got all my system and wiring kit now but.... the place cant fit it for me for about a week which i'm not too impressed about lol.
where do i run the wires... through the grommet behind the glovebox ? then do i need to take the plastic out by the sides of pass door and run it all through>?
how hard is it to remove the plastic ?
i didnt get any plastic wire guard stuff fo the wire that go's through the engine so i need to get some of that tonight, from somewhere lol duno where tho[/b]
#8 OFFLINE   chrisjs
chrisjs
  • 425 posts
Posted 02 June 2008 - 07:56 PM
wiring my amp wasnt too bad. It was a bitch installing my headunit though. i just ran all my wires through under my centre console n earthed in the bootunder the carpet. i had to take up the rear carpet and undo a few bolts on the plastic trim which holds your seatbelt on. half a days work though. = MTX amp mounted on seats and 2- 12inch infinity subs.
got my components fitted as well but had to make a slight frame for them to sit in as my window wouldnt go all the way down :wink:
#9 OFFLINE   ross27
ross27
  • 1117 posts
  • LocationScotland
Posted 02 June 2008 - 08:04 PM
Run your power down the side of the car, and the phono leads down the centre!
The side plastics just pull off mate. Start at the passenger footwell, and pull of the cover, then pull up along the door sill section.
You will need a 14mm(?) socket to take off the seatbelt bar, and then the plastic will come off.
I left the last plastic section on and fished the wires behind it and then out under the rear seat bench. The seat bench is held on with one 10mm(?) bolt. It is just off centre of the middle seat. It will lift up and there are two clips at the front of the bench that will pull out.
Pretty easy mate. I earthed mine is a empty bolt hole in the spare wheel section.
While at it, a also ran new speaker cable from the amp to the front speakers. This was tricky, having to get the wires through the grommet going to the door is hard, cut my hands up big style. but sound was definatly better than tapping into the cars wireing.
#10 OFFLINE   BaRnEsEy
BaRnEsEy
    Forum Master
  • PipPipPipPipPipPipPipPip
  • 6865 posts
  • LocationNorth East England
Posted 03 June 2008 - 06:34 AM
all that reminds me i need to get my old disk changer cable out of my car, its tucked in the boot and under the passenger footwell it runs along the passenger side under the plastic but i dont know where once it gets to the back seats... it just seems to vanish.
i would pull it off but tried a while back and nothing budged at all.
#11 OFFLINE   sirdanmartin
sirdanmartin
    Newbie
  • 2 posts
  • LocationSurrey
Posted 05 February 2011 - 02:17 PM
Hey guys, im currently wiring up my old sound system into my ep2.
I have installed the head unit, changed the door speakers and wired in my parcel shelf 6x9's.
I have wired up my sub to the head unit but am unsure where i can run the power cable from the battery into the car, in my old car there was a rubber grommet i just cut a small hole in.
Does anyone know where i can run the cable or if there is a tut out there? iv had a look around a few forums but had no luck
#12 OFFLINE   Akay
Akay
  • 160 posts
Posted 08 February 2011 - 08:45 PM
On the passenger side were the glovebox would be, look there in the engine bay... huge grommit.
