I reckon if he wanted to he could fit something much better than a k20... Maybe a 1JZ... Or a 2JZOr an RB26? The possibilities are endless if you have the time/skill/money
He has. James' a legend
Posted 26 August 2013 - 08:05 PM
Posted 28 August 2013 - 08:15 AM
What has he done?
Posted 28 August 2013 - 09:58 AM
What has he done?
Posted 28 August 2013 - 05:17 PM
Everything. He has skill/time/money
dont forget the herpes
Posted 28 August 2013 - 09:01 PM
How can you forget the herpes pfft ![]()
Posted 01 October 2013 - 10:59 PM
The car has been off the street for amost 2 months now for the electrical work I talked about earlier ( the work wasn't continuous, I've been on vacation, I then had to work on some school issues and stuff... )
I plasti dipped the pillar and roof plastic trim bits as the black paint peeled of badly, re-upholstered the pillar trims, installed the buttons into the Bpillars for seat movement, re-did sound deadening the rear sides.
I also did a lot of wiring, I'll add pictures later once it is fully finished.
I also pre-wired the subwoofer and amplifier, blind spot assist system, soft close for doors, boot power socket, power tailgate.
I also installed the camera module.
183.jpg 171.77K
9 downloads
184.jpg 149.34K
9 downloads
185.jpg 79.48K
9 downloads
186.jpg 68.12K
10 downloads
187.jpg 98.5K
9 downloads
188.jpg 90K
9 downloads
189.jpg 71.92K
11 downloads
190.jpg 131.56K
11 downloads
191.jpg 179.33K
12 downloads
192.jpg 133.17K
14 downloads
193.jpg 116.97K
12 downloads
194.jpg 138.31K
12 downloads
195.jpg 122.84K
15 downloads
196.jpg 125.87K
14 downloads
More pictures yet to come.
Posted 10 November 2013 - 02:51 PM
So:
- I finished the wiring.
- got the interior back together.
- finished the sound deadening.
- re-done the wiring inside both seats, tidied it up. Re-wired the seat heaters.
- Before that I relocated the side airbag crash sensors into the space of the middle console because they were in the way of the seats at the sides. I made a bracket and welded it onto the floor.
- I have visited the welder and re-welded the boot mounts for the hydraulic struts for the power tailgate.
- pre-wired the subwoofer and ampilifer.
- got a cat.
- cut a hole into the dash for the camera buttons ( I yet have to draw the icons for them and have them laser engraved ).
- replaced the bulbs in the doors for smd leds for power consumption reduction.
- fitted new carpets with a high cut.
- pre-wired the button for the blind spot assist ( I yet have to draw the icons for it and have it laser engraved ).
- wired the button for the fuel filler flap and power tailgate, again, the icons are yet to come.
- wired a new amplified antenna for the dvbt tuner for improved perception.
- hoovered, cleaned and treated the front leather seats
- got a set of e60 bmw 5 rear leather seats, modified the bench quite a bit so it fits, the backrest part is yet to be done. These rear seats are much more comfortable that the standard ep seats. They are upholstered in leather of course, and they have quite a lot of side support on both the bench and more on the backrest part. So now sitting in the rear won't be like sitting in a jail cell.
- wired the ceiling console so now the buttons are back-lit and the orange ambient lighting works again.
- auto-headlights wired and working again.
- replaced the bulbs in the centre console since they were shot.
- wired the pac-swi steering wheel control, but I'm experiencing problems with it so I will probably be returning it
- wired in the clutch pedal and cancel button into the cruise control so now I can cancel it via the button on the steering wheel and it also stops after depressing the clutch pedal ( for safety purposes ).
- pre-wired the power cables to the soft close doors ( that I may or may not fit sometimes in the future, depending on the complexity and if I have time for it ).
- pre-wired the armrest heaters ( will be fitted with new doorcards ).
- wired&fitted a power outlet into the boot.
- fiberglassed a part of the subwoofer encolsure into the boot.
There was more but I can't remember right now...
Yet to come, I have got to change the fuel filter, front engine mount, exhaust downpipe gasket, lube the rear bushes, replace the front CV joints and repair the front top mounts
Some pictures:
20131005_191243.jpg 104.08K
12 downloads
20131005_191252.jpg 122.08K
12 downloads
20131007_020929.jpg 135.21K
13 downloads
20131006_211853.jpg 95.45K
15 downloads
20131009_180400.jpg 171.25K
13 downloads
20131009_180412.jpg 189.68K
12 downloads
20131009_183235.jpg 75.44K
13 downloads
20131009_183324.jpg 163.16K
12 downloads
20131108_140810.jpg 71.59K
12 downloads
20131108_142205.jpg 74.75K
15 downloads
20131108_142213.jpg 124.84K
13 downloads
20131108_142354.jpg 132.37K
15 downloads
20131023_1518281.jpg 134.5K
14 downloads
20131025_1630441.jpg 99.69K
12 downloads
20131025_1809021.jpg 97.3K
13 downloads
20131026_211441.jpg 130.01K
12 downloads
20131026_211520.jpg 175.87K
12 downloads
20131027_170833.jpg 125.99K
15 downloads
20131028_010951.jpg 117.98K
14 downloads
20131028_011000.jpg 115.42K
12 downloads
20131110_043945.jpg 62.63K
13 downloads
Posted 10 November 2013 - 03:00 PM
Posted 10 November 2013 - 03:07 PM
Once I finish fitting them and re-upholster the doorcards I will have them painted brown to match the front seats ( special paint suited for dying leather of course ).
And cats are awesome, I should have gotten one a long time ago ![]()
Posted 10 November 2013 - 04:45 PM
Posted 29 November 2013 - 01:26 AM
I replaced the outer CV joints, but I realised, that the clunking problem is being caused by the inner cv joints or differential, so I am going to leave that for later now.
I also replaced the front engine mount since that was snapped off.
201.jpg 156.21K
20 downloads
202.jpg 133.69K
21 downloads
203.jpg 200.88K
20 downloads
Posted 04 December 2013 - 09:12 PM
And I was wondering why my rear screen washer wasn't working.... ![]()
206.jpg 141.15K
15 downloads
208.jpg 158.66K
17 downloads
The tube probably melted when welding the mounts for the hydraulic struts.
So I replaced it with a tube of the same diameter, used the original clips etc.
204.jpg 139.09K
19 downloads
205.jpg 131.86K
21 downloads
Posted 04 December 2013 - 10:06 PM
James - would it be possible for you to grab a pic of what the headliner looks like? I'm tempted to do mine black aswell as the A pillars like yourself ![]()
Posted 13 December 2013 - 06:44 PM
there are pictures on this or the previous pages of it.
I adjusted the valve clearances today, a bit late but better than never.
This is how my engine head looks after about 220k km, quite healthy I think.
20131213_1557371.jpg 139.23K
14 downloads
20131213_1558221.jpg 176.2K
17 downloads
20131213_1716261.jpg 208.16K
18 downloads
