i set up my new sub yesterday, but coming across a wee problem with the ground wire, where did yooz attach yours, ive been touching everything in the boot and ended up just attaching to the jack for the time being
Posted 06 July 2009 - 04:44 PM
Posted 06 July 2009 - 06:58 PM
Posted 23 March 2010 - 06:51 PM
Awryty
i set up my new sub yesterday, but coming across a wee problem with the ground wire, where did yooz attach yours, ive been touching everything in the boot and ended up just attaching to the jack for the time beinghelp please lol
Posted 23 March 2010 - 07:11 PM
You can use any point that is attached to the frame or shell of the car. Sand abit of the paint off so you get contact with the bare metal and you're good to goSorry to bring up old threads but ive got the same problem, need to wire my amp. Had a look and found the strut bar in the boot, can this be used to ground the amp?
If not how do you lift up the rear seat cushions? I can't seem to get them lifted up.
Posted 23 March 2010 - 10:10 PM
Posted 23 March 2010 - 10:19 PM
I haven't got a clue what part you mean, but almost everything in the boot is attached to the chassis so unless you try to ground into plastic (or something) you should be alright.Ah good so I can use that metal strut bar type thing that runs down the back of the seats at the start of the boot? Just need to sand it all of to bare metal?
Was worried about not grounding it on the right bit...
