URGENT: Pics of EP3 spoilers modified to fit EP2 needed
Posted 23 June 2009 - 03:37 PM
The problem is, I've done it once already and the finish wasn't amazing. Up close, you could see where the cuts had been made if you were to look in the small gap between the spoiler and the tailgate.
I could do with a load of pics showing exactly how the spoiler was cut, from all angles. Currently I've only seen the birds eye view, which is impossible to tell depth.
Need this ASAP as I will be doing the guide this weekend.
thanks in advance
Posted 23 June 2009 - 03:39 PM
But I could do with a few from a side angle to determine depth etc. Also a pic of how this then rests on the car (being able to see between glass and the spoiler)
Posted 23 June 2009 - 05:02 PM
i have pics on my build up which are close ish of it fitted they should help a little bit.
Posted 02 September 2009 - 02:30 PM
Posted 03 September 2009 - 11:03 AM
You need to cut quite a bit of, but do it bit by bit an fit it to see it on. Don't cut to much at once because you'l get a gap between the spoiler and the window if you do.
Posted 02 September 2014 - 08:07 PM
What did you use to make the cuts buddy and was it easy? cheers
oh and what about the brake light?
#7
Posted 10 October 2014 - 09:19 AM
im curious to know tool was used to cut as well ...i heard you need to drill a hole for the brake light too.
any one who is able to help will be appreciated
#8
Posted 11 October 2014 - 09:32 AM
#9
Posted 06 February 2015 - 09:08 PM
why not get a wide strip of double side tape and cover the cut out and stick the spoiler to the glass
no visible gap
#10
Posted 11 February 2015 - 03:05 PM
If you look at the standard EP2 spoiler, you'll see that there's a step where it reaches the rear window, and thins down to sit on top of it.
Basically just create the same sort of thing like so:
I used a small hacksaw and a flat file - It's slower but easier to control for super flush fit. Just keep test fitting. Essentially you want the cut to be at the level of the rubber pads on the spoiler so that it'll all sit flat.
After that, drill a hole for the brake light in your boot lid (8mm I think), remove the clip from the brake cable (you do this by lifting up a little flap that's clipped down, then pulling), feed the cable through the hole in the boot, reattach the clip and then connect it to your existing brake light connection.
I used some heavy duty outdoor velcro between the spoiler and the window to stop it from rattling and help keep it strongly attached.
#11
Posted 17 January 2016 - 04:09 PM
I used a Dremmel to do the same thing.
Cut, Sand, Check, Repeat
