Eibach Sportlines Fitted!!!!! =D
66 replies to this topic
#1 OFFLINE   MattyP!
MattyP!
  • 1444 posts
Posted 08 April 2009 - 09:40 AM
Sportlines or Pro kit. BOOKED!!!
Whats best to have? :o 8-)
#2 OFFLINE   Cody
Cody
  • 1476 posts
  • LocationSutton Coldfield
Posted 08 April 2009 - 07:55 PM
Im goin pro when I EVENTUALLY lower it so i'd say Pro!
#3 OFFLINE   paz_000
paz_000
    Elite Member
  • PipPipPip
  • 544 posts
  • LocationEast Sussex
Posted 08 April 2009 - 10:59 PM
i got sportline but i deffinatly recoment getting camber kit as bro had them on hisand his tyres wore to fck hence why i have eibach front springs and Type R rear springs, personally i hink its more level with Type R rears.
#4 OFFLINE   john_ep2
john_ep2
  • 440 posts
Posted 09 April 2009 - 04:20 PM
pro-kit won't lower facelift, not noticeably anyway. will improve the handling a bit though...
sportline will lower facelift approx. 30-35mm.
pro-kit lowers pre-facelift approx. 30mm and sportline approx 50mm
#5 OFFLINE   sam01
sam01
  • 287 posts
Posted 04 May 2009 - 01:43 PM
http://www.potn.co.uk/p1331657.htm
Going on by what you have said, I have found this set of Eibach Sportline springs for my 2004 ep2..
It says "This kit Front lowers by: 45-50mm and rear lowers by: 30mm"
Has anyone purchased this set of springs and had problems with scraping at the front?
Dropping 30mm at the back im not worried about.. but 45-50mm at the front, will this cause scraping in anyway?
#6 OFFLINE   MattyP!
MattyP!
  • 1444 posts
Posted 04 May 2009 - 02:50 PM
Still not brought these but will be going in about 2-3weeks :D
Think im going Sportlines as i have a Non Sport EP2 which is alot higher!! aha
#7 OFFLINE   Remould
Remould
  • 3032 posts
  • LocationSurrey
Posted 04 May 2009 - 09:04 PM
Yeah, the Eibach Sportlines lower the car more than the Pro's (-50mm as opposed to -30mm).
Go for the Sportlines, that's what i have. :D
#8 OFFLINE   alby8
alby8
    Expert Member
  • PipPipPipPip
  • 861 posts
Posted 04 May 2009 - 09:31 PM
I had the pro kit on my ep2 and was never really happy with the drop tbh. The pro kit is probably more suited to our roads and a better kit, but id still have the sportlines just for that extra drop.
#9 OFFLINE   fergie1471
fergie1471
  • 225 posts
Posted 05 May 2009 - 12:50 AM
Here is some pics of when i had the sportlines mate:
hope this helps
#10 OFFLINE   MattyP!
MattyP!
  • 1444 posts
Posted 05 May 2009 - 08:48 AM
Sportlines it is then!
Will have to be 2 weekends time as im busy for the next two aha
With the Sportlines did you have to buy anything else or jsut the springs?
as i've been told about Camber adjusters is it? or something like that?
thanks
And Fergie i like the drop!
And the Mugen Splitter how much was that =P
#11 OFFLINE   Remould
Remould
  • 3032 posts
  • LocationSurrey
Posted 05 May 2009 - 12:26 PM
I would highly recommend getting 14mm Eibach camber bolts up front and a set of Adjustable Upper Arms for the rear. This with a Fast Road setup will dramatically change the handling of your car.
People will tell you that you don't need to do this but you will wear the tyres out quickly if you don't get the suspension set up properly...
IIRC you can get a set of Camber Bolts for about £15 and there are plenty of Adjustable Upper Arms from £50+
For example, these will fit:
http://cgi.:).co.uk/Suzuki-Grand-Vita ... =72%3A1683
http://cgi.:D.co.uk/D2-Rear-Camber-ad ... =72%3A1683
Hope this helps! :D
#12 OFFLINE   MattyP!
MattyP!
  • 1444 posts
Posted 05 May 2009 - 01:29 PM
Thats great mate.
I've been reccomneded a place called Demon Tweeks that will supply and fit.
they also will set up for me which is included in the price.
Will i need these adjustable upper arms even if im going to have it all set up?
thanks for your help =D
#13 OFFLINE   Remould
Remould
  • 3032 posts
  • LocationSurrey
Posted 05 May 2009 - 02:06 PM
Yeah, Demon Tweeks are a great company. I have purchased parts from them many times in the past.
I take it you mean this place? http://www.demon-tweeks.co.uk
You will need to purchase and fit the Camber Bolts and Adjustable Upper Arms yourself. I don't know if Demon Tweeks even supply them... :D
They certainly won't include the fitting of them in the same price as fitting the springs unless they have already told you that. I'm sure if you supply the parts, they can fit them for a small fee. Give them a call. :D
Seen these on Demon Tweeks website:
Front:
http://www.demon-twe... ... BE5.81250K (you'll have to call them asking for the correct 14mm fitment).
Rear:
http://www.demon-twe... ... 230K&app=Y
What set up are they doing on your car? Standard or Fast Road? I have posted many times telling people what settings i have used. If you are interested and can't find the info, give me a shout, i'll let you know the settings.
Cheers, Steve.
#14 OFFLINE   tom-9999
tom-9999
  • 463 posts
Posted 05 May 2009 - 02:07 PM
yea you will im looking into it for lowering mine d2 rear arms and thinking eibach or d2 front bolts as both about £25
#15 OFFLINE   MattyP!
MattyP!
  • 1444 posts
Posted 05 May 2009 - 04:05 PM
thanks Remould :D
I have spoke to Demon-tweeks.co.uk a few times now and they seem great!
£316 for Eibach Sportlines and a Fast Road Set up.
Other than that i have another option of having a local garage ((www.topgear.co.uk) this is where i got my rota's from and fitted.) supply and fir them for me, but cannot do me a fast road set up.
But there is a Hi Q tires down the road who can do 4 wheel allignment and camber adjustment for £60.
Topgear.co.uk have also said i wont need the adjusters, whats your opinions on this?
As demon tweeks is about hour and half away from me.
if you could PM me with your Fast Road settings that would be great mate.
thank you
