big ass problem!!!
Posted 27 June 2008 - 02:48 PM
machanic at the garage asked me if a spin it alot, thing is i dont spin it at all, jst got a heavy right foot
Posted 27 June 2008 - 02:56 PM
id question it more. but then they thought, modified = flogged so you done it why should they fix it for free.
shouldnt cost all that much, maybe get a low miler from a scrappy?
Posted 27 June 2008 - 03:18 PM
Posted 27 June 2008 - 06:16 PM
If so, ive had this noise for 2.5 years, and it aint the gearbox.
Gearbox noises are normally heard at low revs whether accelerating or de-accelerating and if it was arnold clark Kirkcaldy you took it to, i wouldn't belive a word they thick fuckers told me.
Posted 27 June 2008 - 07:00 PM
I mean on mine, put it in neutral and lift the clutch and theres a whirring noise, sounds like bearings. Only when the clutch is lifted.
Spoke to a mechanic about it, he said dont worry about it, nothings going to happen to it. But if i really wanted to, i could change the gearbox oil/transmission fluid, and see if that made a difference.
Im not going to bother. Been like that for about 3 years
Also, you could take the mods off, and take it to another garage?
Posted 27 June 2008 - 08:09 PM
Posted 27 June 2008 - 08:30 PM
Quite common i have heard.
I suppose you could try changing fluids?
Posted 27 June 2008 - 11:59 PM
EP2, do you get it only when the clutch is raised?
Mine only does it when the revs are falling, even if the cluth is down (dis-engaged) to change gear.
Posted 28 June 2008 - 12:44 PM
mine is doing aw of that but the noise is definately gettin worse, took it to rjm in glenrothes first, booked in at arnold clark on wednesday tho. noise gets worse/louder when the revs go up but its all thru the rev range
Posted 01 July 2008 - 09:37 PM
Posted 02 July 2008 - 10:04 PM
also asked the boy if its awryt to drive said it is jst noisey! fuk that tho no worth the risk
any1 that has the same noise ad get it looked at b4 it gets like mine!
Posted 06 July 2008 - 09:57 PM
Posted 06 July 2008 - 10:44 PM
On the CRTO forums people says it the heatsheild on the cat or manifold, ive not looked to be honest
Posted 05 August 2008 - 10:42 AM
Posted 18 September 2008 - 01:44 PM
There is a very helpful and very specific piece of law-related writing on EPhatch regarding this issue. It pretty much lets you know what mods will void it. Prepare yourself with a cuppa and some biscuits though, it's a long read!
