Bootlid issue
5 replies to this topic
#1 OFFLINE   kam_786
kam_786
    Junior Member
  • Standard Members
  • 98 posts
Posted 06 August 2012 - 03:47 PM
Boot lid doesn't want to open anymore :s
Anyone ever had this issue or know how to fix it? Really beginning to annoy me as I'm having to go inside and pull the back seats forward to put stuff in the boot
I've tried opening it with the key but still it doesn't work, I can hear the lock unlocking and locking but still the can't seem to open the actual boot
Any help/advice appreciated! thanks!
#2 OFFLINE   lunacide
lunacide
  • Standard Members
  • 210 posts
  • LocationMintlaw, Aberdeenshire
Posted 06 August 2012 - 04:28 PM
boot handle seized up maybe? try spraying wd40 in it and trying to open the boot a fair few times...hopefully thatll work
#3 OFFLINE   Spectre
Spectre
  • Standard Members
  • 1715 posts
  • LocationE
Posted 06 August 2012 - 05:44 PM
Press it down while squeezing the handle and see if shaking it will release it. Could be a problem with the lock itself but in most cases its down to build up of greasy dirt that cloggs it all up. Just needs a clean and an oiling and it'll usually be fine. :)
#4 OFFLINE   andrewfoggo
andrewfoggo
    Junior Member
  • Standard Members
  • 44 posts
  • LocationDerby
Posted 06 August 2012 - 06:04 PM
had this issue on mine, when i went to fix it- it started working again. havent looked at it since but i think its just a build up of crap at the mechanism
#5 OFFLINE   big1.chris
big1.chris
    Elite Member
  • Standard Members
  • PipPipPip
  • 683 posts
  • LocationGlasgow
Posted 06 August 2012 - 07:21 PM
My ep2 done this there's a wee slot I could get a screw driver threw and unjam it on their side of the boot it would work for a bit then fuk up again after that
#6 OFFLINE   Marfat Ali
Marfat Ali
    Newbie
  • Standard Members
  • 27 posts
Posted 07 August 2012 - 01:14 AM
lock the car with imobiliser, make sure boot lid latch is pushed back, then unlock with imobiliser then pull latch forward...
i have this problem with the latch but this technique always works
