EP1 Turbo
#76 OFFLINE
Posted 30 August 2009 - 07:25 PM
#77 OFFLINE
#78 OFFLINE
Posted 30 August 2009 - 08:31 PM
With this i can wire the greddy in no time...
2001-2003 Honda Civic ECU Wiring
Connector A (31 Pins)
1-blk/wht-Primary O2 sensor heater control
2-yel/blk-Power Source
3-yel/blk-Power source
4-blk-Power ground
5-blk-Power ground
6-wht-Primary O2 sensor
7-blu-Crankshaft position
8-yel-Sensor return volt
9-red/blu-Knock sensor
10-grn/yel-Sensor ground
11-grn/wht-Sensor ground
12-blk/red-Idle air control valve
13-wht/blk-EGR Valve position VTEC ONLY
14-blk/wht-Secondary O2 sensor heater control
15-red/blk-Throttle position sensor
18-wht/grn-Vehicle speed sensor
19-grn/red-MAP Sensor
20-yel/blu-Sensor Voltage Supply
21-yel/red-Sensor Voltage Supply
23-brn/yel-Logic ground
24-brn/yel-logic ground
25-wht/red-Secondary O2 Sensor
26-grn-Top dead center sensor
27-brn-Igniton coil 4
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
Connector B (24 Pins)
2-yel-Fuel injector 4
3-blu-Injector 3
4-red-Injector 2
5-brn-Injector 1
6-grn-Radiator fan control
7-red/blk-A/T Pressure control solenoid valve A
8-red/wht-Engine Coolant sensor
9-blu/blk-VTEC Oil pressure switch VTEC ONLY
10-wht/blu-Alternator L Signal
13-wht/red-Alternator FR Signal
14-blu/red-EGR Valve VTEC ONLY
15-grn/yel-VTEC Solenoid valve
16-blk/red-A/T Pressure control solenoid valve B
17-red/yel-Intake air temp sensor
18-wht/grn-Alternator control
21-yel/blu-EVAP Canistor purge valve
Connector C (22 Pins)– AUTO TRANSMISSION ONLY
1-wht/blk-A/T Pressure control solenoid valve A
2-yel/blu-Torque converter clutch solenoid
4-grn/wht-Shift solenoid B
6-blu/blk-Shift Solenoid A
7-wht/red-Mainshaft speed sensor
8-brn/wht-A/T Pressure control solenoid valve B
9-red-Position switch D3
10-wht-position switch R
11-blu-position switch 2
12-blu/wht-position switch neutral or park
14-grn-countershaft speed sensor ground
15-blu-countershaft speed sensor
18-blu/yel-position switch D3 or D
20-yel-position switch D
21-wht/grn-mainshaft speed sensor ground
Connector E (31 pins)
1-grn/yel-Immobilizer fuel pump relay
2-wht/red-Secondary O2 Sensor EX Only
4-pnk-Sensor ground
5-yel/blu-Sensor voltage source
6-blk/wht-Secondary O2 sensor heater control EX Only
7-red/yel-PGM-FI main relay 1
9-yel/blk-Ignition input signal
12-blu/orn-Cruise control signal
13-wht/blu-Interlock control unit
14-lt grn-Fuel tank pressure sensor
15-grn/red-Electrical load detector
16-lt grn/blk-Power steering pressure switch
18-red-A/C Clutch
20-blu/red-EVAP bypass solenoid valve
21-lt grn/red-EVAP Canister shut valve
22-wht/blk-Brake pedal position switch
23-lt blu-K line
24-yel-Multiplex control unit comm line
26-blu-Engine speed pulse
27-red/blu-Immobilizer code
29-brn-Service check signal
30-red/wht-Write enable signal
31-grn/orn-MIL or check engine light enable
#79 OFFLINE
Posted 31 August 2009 - 01:52 PM
u go for it !!! EP1! FTW !!!
#80 OFFLINE
#81 OFFLINE
#82 OFFLINE
Posted 01 September 2009 - 12:15 PM
#83 OFFLINE
Posted 01 September 2009 - 06:35 PM
4-pnk-Sensor ground
18-red-A/C Clutch
23-lt blu-K line
3-blu-Injector 3
4-red-Injector 2
5-brn-Injector 1
4-blk-Power ground
5-blk-Power ground
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
This is good news as this is a step forward to connecting the emanage!
#84 OFFLINE
Posted 01 September 2009 - 06:43 PM
#85 OFFLINE
Posted 01 September 2009 - 06:47 PM
Hey coco-loco, I don't have VTEC, but I think Apox might be able to help u with this using these schemes. It's like reading Latin for us, but babies fairy tale for him ...
#86 OFFLINE
Posted 01 September 2009 - 06:57 PM
also i don't think emanage deals with vtec as you can use it on other cars without variable valve timing
#87 OFFLINE
Posted 01 September 2009 - 07:25 PM
This is the closest I can get, the wiring of an S2000. Good news is, half of the connections seem the same as EP1/EP2. Bad news is, some are different.... Apox will find a way for sure, and the vtec connections seems easy too
This would be my translation of this scheme from S2000 to EP1/EP2:
TPS signal: connector A15-red/blk-Throttle position sensor
VTM: ??? possibly S2000 specific differential/oil pressure signal (I really don't know)
IGP1: connector E9 -yel/blk-Ignition input signal
PG1: connector A:
4-blk-Power ground
5-blk-Power ground
RPM/NEP: connector E26-blu-Engine speed pulse
And specially for coco-loco=>
connector B15-grn/yel-VTEC Solenoid valve
emanage sure DOES deal with VTEC, allows u to modify your VTEC kick in point
Good news for this one! Same for S2000/EP1/EP2, tnx to Honda for making this easy
Don't know for the grounding:
PG1: connector A:
4-blk-Power ground
5-blk-Power ground
probably one of these...
I leave this one to Apox, as I have no clue what's this one about!
Probably connector A:
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
Phew.... this one took me a while to figuere out Enough wires for today!
#88 OFFLINE
Posted 01 September 2009 - 07:28 PM
#89 OFFLINE
Posted 01 September 2009 - 07:33 PM
good work, im very impressed! hopefully my mechanic will make sense of it
Even I can make sense out of it, and I'm nowhere near a mechanic's skills My guess is, it's noobproof, only we are screwed since it's not intentionally made for EP1/2
#90 OFFLINE
Posted 01 September 2009 - 07:38 PM
