Red H badges: All you need to know (incl sizes/removal)
Posted 19 June 2009 - 11:01 AM
Quite a common modification for the EP1/2 is to change the somewhat boring standard 'H' badge located on the tailgate, front grille and steering wheel, to the Type-R style red badges.
As the topic is pretty common, there's always a thread asking what size they need, will these ones on fit, what are the part numbers or how do I remove the badges?
So here's all you need to know, click the links to be re-directed to that section.
* Which badge to get (including measurements and part numbers. All measurements are within 1mm)
* How to remove the Rear Badge
* How to remove the Grille Badge
Posted 19 June 2009 - 12:23 PM
Which badge to get?
FACELIFT MODELS (2004-2005)
Front Grille badge:
Measurements = 99mm x 122mm ( 3.93" 4 83").
Honda Part Number: 75700-S5T-E11
PRE FACELIFT MODELS (2001-2003)
Front Grille badge:
Measurements = 74mm x 92mm ( 2.94" 3 64").
Honda Part Number: 75700-S5T-E01
BOTH MODELS
Tailgate badge:
Measurements = 51 x 64mm ( 2.04" 2 52").
Honda Part Number: 75701-S5T-E01
Steering Wheel badge:
Unless you want to spend £100 on a Type-R steering wheel, there is a £5 workaround.
You can purchase the red steering wheel sticker from here for only £5. What's more, you'll be supporting epcivic.com!
Posted 19 June 2009 - 12:24 PM
Posted 02 September 2009 - 08:28 PM
Posted 06 September 2009 - 10:27 AM
Posted 06 September 2009 - 01:55 PM
Does a facelift ep3 red h badge fit a facelift ep2 grill?
yes
Posted 04 November 2009 - 07:36 PM
Posted 14 June 2010 - 11:25 AM
Thanks Damon
Posted 16 June 2010 - 01:50 PM
Tigerseal (might be tigerbond) will do it nicely.
Posted 19 June 2010 - 11:56 PM
Posted 20 June 2010 - 09:59 AM
i've just bought a prefacelift red badge for the front (checked the part number = correct.) and it doesn't seem to fit. my OEM EP2 badge is slightly larger then my EP3 front badge. What 's wrong?
the pre facelift is a different part number to the facelift and thus smaller...
Posted 27 June 2010 - 09:29 PM
whats the glue called thats currectly used on the honda bagdes?
that would really help.
thanks
Posted 27 June 2010 - 09:40 PM
u doin it liek this?
Posted 27 June 2010 - 10:14 PM
i just want a glue that is firm but also easily removable.
isnt there a glue that is similiar to sticky pads
