recaro resistors installed
Posted 21 June 2008 - 12:33 PM
1, got resistor kits 1 for each seat thanks to NHBANDYD for finding them and informing us all about there existance .
2, as my seats where already installed by the previouse owner we only needed to look at these 2 parts of the instalation diagram, shown here.
3, We disconnected the cars battery and waited 10 mins, we then located the yellow honda block conencted to the car from under the seats. (note we didn't need to touch the wires comming from the drivers seat as this is now inactive.
4, We then took off the yellow honda blocks and stripped back the wires connected to the car. (note we didn't touch the brown seatbelt connector and plugged this back in once everything was done)
5, we then crimped on the new female spades supplied with the resistor kit and inserted them into the new recaro block (see fig 3)
6, We then connected the recaro resistor block into the newly connected recaro block (see fig 4) and reconnected the cars battery.
Posted 21 June 2008 - 01:07 PM
Rockin' a Supercharged 06 NHB Premier R - view
TDi Tuned - 294.9 bhp 191.3 lbft @ 6 psi
JRSC | KPro | Gruppe M | Piper | CPL | HKS | Recaro | Rota | ABP | HID | SFS | JDM
05 NHB EP2 - bye! > 06 NHB EP3 - hello!!
Daily : Nissan Juke Nismo RS
PSN : ashpb | XBOX : a5hpb
Posted 21 June 2008 - 02:09 PM
Posted 21 June 2008 - 07:16 PM
From an american site but the panel looks the same i think
^^ MES Plug ^^
BTW: You dont need a SCS Service Connector, a paper clip bent into a 'U' shape is what i used, make sure the lengths are the same as you need to plug each one into the yellow plug at the same time to complete a circuit.
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect.
Posted 21 June 2008 - 08:46 PM
Posted 21 June 2008 - 10:34 PM
Posted 21 June 2008 - 10:48 PM
i had to unclip 2 of the main wire looms that come from the dash just to fing the yellow plug.
if you have any trouble doing it just give me a shout, also it'll save you £85.
Posted 22 June 2008 - 10:11 AM
Posted 22 June 2008 - 10:20 AM
Posted 22 June 2008 - 12:05 PM
the cable connected to the car
the cable connected to the seat
or the recaro plug?
Posted 22 June 2008 - 03:09 PM
Posted 22 June 2008 - 03:53 PM
stripped back the cables connected to the car mate. didnt need to touch the seats .
oh right, will have to sort this out then on mine, but does it mean once done you wont be able to put the old sport seats back in? if for some reason i took the type r ones out?
where did you get the recaro plugs from?
Posted 22 June 2008 - 03:56 PM
Posted 22 June 2008 - 04:12 PM
Posted 22 June 2008 - 10:46 PM
but you stripped the wires and what not
